Thank you all for replying!
Due to me living in SE Asia shipping costs are a killer for getting items sent to me like this from America or Europe!
With this in mind I decided to try and make up a Angle plate, it seemed easy enough.
I cut up two pieces of fairly thick steel (12mm+) made a 90 degree jig for holding the items then using a arc-welder
lay down a couple of beads of steel on the inside of the 90.
I decided not to put in a web as I wanted to put this item into my milling machines vise and use it to hold the angle plate while milling.
I tried first of all to clean up one of the edges that where cut with my cut off saw, as the edge stood fairly high off of the vise
I went with a light surface cuts. All went well with just a bit of vibration, I deepened the cut maybe to .25mm, the cut started,
then Bang, the tool hooked on the plate and was thrown to the side, the steel weld was bent over and one of my carbide inserts
in the cutting was chipped off. I removed the plate from the vise and straighten it back to 90 degrees and stopped the project.
If trimming up the edge causes this much problem what would happen when I would attempt to cut the slots in the angle plate?
My thoughts are putting is a couple of webs for support, this will of course help with rigidity but that means the vise is now out of the question. Harold Hall recommends using the table and vertical squares, based on his comments and the size of my T-slots I will need 2" round stock which I do not have. I have only a small lathe (S2) and do not have a steady rest as of yet, so facing the ends will be a issue using only the three jaw chuck for support.
As a novice it seems that one takes one step forward and two steps back!
