All it is is a post with a t-nut at the bottom and thread at the top for a nut. If it's faster/easier/cheaper to carve up the t-nut blank for your compound do that, it's it's faster/easier/cheaper to make all new then do that. I've made em, adapted 'em, tossed old ones away.
All that really matters is that the t-nut puts the top of the compound in compression (pinching the top between the t-nut and the TP base), that the post is pinned or welded to the t-nut (I prefer pinning so it can move a bit) and that there's sufficient thread at the top for a nice high nut. Bonus points for a t-nut wide enough to allow the TB positioning anywhere on the compound, a post that's a closeish fit in the TP and a rounded top to the post so you don't snag your forearm on sharp threads.
