I'm timidly going back to my hobby, building model engines (do you remember that I had stopped the work on the Scuderi engine a while ago?)
a couple of days ago I was cutting a piece of steel on the lathe and noticed that on a lenght of about 120 mm for a diameter of 35 mm I had a difference of 1-2/10 mm in diameter from end to end (35,2 at one end, 35,3-35,4 at the other)
so I started to think, consider, imagine... till I reach the conclusion that I need to rebuild the lathe
it is a VERY old lathe, 80 years old, Boley 4L screwcutting lathe
browsing the web and Ebay, I found this auction:
http://cgi.ebay.it/910mm-R-J-H-Cast-Iron-Ground-STRAIGHT-EDGE-Unused_W0QQitemZ170385546577QQcmdZViewItemQQptZUK_Home_Garden_PowerTools_SM?hash=item27abc51d51&_trksid=p3286.c0.m14
and was going to buy the item to control the scraping of the ways of the lathe
fortunately, I posponed the purchase to verify first the lathe setting
after an hour of fine adjustment with DTI I was able to obtain an error of 0,02 - 0,03 mm in the same conditions above, and even better with more care in setting up the work
well, I saved about 200 $ on the straight edge, and more if I count the other necessary tools to rebuild the lathe
and a lot of time and frustrations without knowing if I really could had been able to do a right work
it would have been a real mistake to start this adventure! ???
but a question remains... I noticed that every little change in the setup has a great consequence in the accuracy of the setup
in my tailstock, also shut the lever that blocks the spindle causes a movement of the DI of several 1/100 mm
and many other parts react in the same manner
so, to maintain the accuracy, is it necessary to check with a DI every stock after that it has been fixed in the lathe? an annoiyng practise, isn't it?
or my old lathe is really too much sensitive to these factors?
thank you
thank you
