- Feb 26, 2020
- 570
- 344
Not having tried any "real" casting so far. So it is all a more or less uneducated question from the "keyboad foundry".
If the gears can be printed in PLA with the lowest possible infill, can the metal be cast directly, leaving the PLA pattern inside the sand?
Like a lost foam casting?
Would Cutting the gear out of foam with a hot wire, be an option?
That would take time because a new pattern for each part is necessary, but it would save you from getting the pattern out of the mold?
When ramming refractory the supervisor showed me to loosely wrap a plastic foil around the pattern, then it slides out more easy.
Based on this I thought how about print the theeth in "vasemode" then put another inside pattern for the spokes in?
a) leave the thin wall teeth inside the sand b) try to remove it carefully to the inside, as it will be flexible.
Greetings Timo
Greetings Timo
