2kmoss
All,
I have completed the build of Farm Boy #495. I spent all of last winter building it and had everything done except the ignition system and getting it to run. I have recently spent several evenings setting up the ignition and trying to get it to run and have had almost zero luck. I got it to sputter a couple of times early on but cant get it to hit a lick now.
The first problem is I am burning up Hall Effect switches like popcorn, they will work for a few hours of trying to get it to run and then zap! I'm sure its some kind of grounding problem sending high voltage thru the switch but am confused as to why as I have this ignition wired up per the provided directions.
When switches are functioning properly I get a nice blue spark that is very audible with the plug out of the hole and just grounded to the head. Once I re-install the plug I kind of hear the spark but it doesn't seem to be as "hot" as when the plug is removed??
I have all governer linkage removed and am just trying to get it to run first before I install and mess with the setup. I have the ignition set to fire right at about TDC. The exhaust opens a bit before BDC on power stroke and closes right at TDC of exhaust stroke. I seem to be getting good compression and the valves seem to be sealed real nice. I am using Coleman fuel and it seems to be flowing well into carb, maybe to well as I can flood it out real easy (fuel starts oozing past cylinder 0 ring if i choke it to much with the needle opened up a full turn).
Ignition Specs: (All ignition parts were purchased thru model-engine-ignition.com)
Battery - 6v using (4) AA Batteries
Ignition Module - PICTIM w/Buzz Coil Chip
Switch - Hall Effect Sensor w/Magnet on Cam Gear
Coil - Power Keg 4 Wire Coil
Spark Plug - Rimfire VR2L w/.020 Gap
Per the instructions the only thing I have grounded to the engine head is one of the secondary leads from the coil. The directions for the Ignition Module states to ground the module to the engine but in the information with the coil states that it is recommended not to ground the Ignition module if using a 4-wire coil. Sooo...
I will attempt to attach a few pictures of the current setup.
Thank you for any help or suggestions you may have!!
Kevin
Kevin
