max corrigan
- Aug 24, 2008
- 156
- 4
A simple question to the machinists among us! what is the correct way to drill (bore)a hole through bronze the hole to be drilled would be roughly 3/8" the length of the hole around 3" i know you would face of each end and centre drill,and then go up from a pilot drill etc. i have drilled longish holes in the past but when the drill comes out the other end it is often off centre
would you start drilling from both ends? then at least you would have two central holes but probably have a bend in the middle as each drill would follow the pilot holes
Also would you put the drill in the tailstock chuck and revolve the job, or visa versa
sorry for these newby type questions but i am not a machinist, so have not been taught the correct approach
Max.......
I hope i got this query in the right section, and not in the general section, please move if need be!
Max.......
