Here is the distributor for a V4 engine. The cap is clear acrylic with stainless screws in it. The rotor is the same with a piece of brass sheet super glued to it. The shaft has a steel disk on it that the magnets are pressed into for the hall sensor. The bevel gear is a match set with the gear on the cam. The brass spacer is used to set the mesh on the gears. The body is aluminum with 1/8 X 1/4 inch bearings pressed into each end to support the shaft.
S/S has started to carry the MJN molded caps but the rest will need to be fabricated. I picked up an 8 cylinder cap from him at the Zanesville show. Nice stuff!
The molded caps are not very deep. If you make your own cap you can keep more distance between the body of the distributor and the rotor. If you foul a plug you will need all the room you can get. Man there is fire shooting everywhere. It's Awesome!!
