Hello,
I was designing an engine to possibly build after looking at Elmers Opposed Piston Steam Engine, but I have a problem.
If the model is rotated CW, the left piston with the upper crank throw leaves the cylinder .035 before the right cylinder.
If the model is rotated CCW, the right piston with the upper crank throw leaves the cylinder .035 before the left cylinder.
The crank throws are 180 degrees apart.
If the crank throws are horizontal, both pistons are exactly the same.
If the crank throws are vertical, the error .035 difference.
I know there is a simple explanation for this, but the more I try to find it, the more lost I am. I can see that this model does this, but I can not figure out exactly why.
I think I can adjust one upper linkage rod .035 to correct this, but this would only work for one direction of rotation. I am trying to make this to run in both directions.
Could someone who can see what is causing this please let me know what I am missing?
Thanks you.
Thanks you.
