Hello,
I have a question about a D bit fixture but first a little background if I may.
I have not yet made or used a D Bit. Actually the more I check into this the more I am confused so I figured I had just better jump in and find out for myself.
I understand that a D bit is not that complicated and fairly easy to make without a fixture, but I would like to be able to reproduce as close as possible a design that works for me.
The pictures below I hope will give you a good idea of what I have in mind.
The fixture is designed to sit in a vise.
First I would (after clamping the drill rod in place) mill the bar to slightly over half with a bull endmill. This is with the fixture level.
Next I would sit the fixture on the 10 degree angle and clamp it in a vise. Then set the angle I wanted by rotating the top portion the desired amount. This should cut the angle and also undercut it for clearance.
Now the question.
For those who have made these before, does it look like I understand the general principle of making a D bit?
Please dont be shy if I have done something stupid in my design. I have been married for 32 years and I am use to getting criticized.
Thank you.
Now the question.
Thank you.
