It looks like I am needing to cut some metric threads and will be required to run the lathe in reverse to return the carriage to the start position. The motor is a GE 1/2Hp 1725rpm with capacitor start. Under the cover plate shows the wiring for reverse rotation. So far so good.
Looking at my options, it appears that most people are using barrel switches. Why couldn't I just use a 20amp SPDT-CO momentary/contained toggle switch?
I am thinking that using the contained side for forward rotation and the momentary side for reverse along with the original on/off switch would keep the lathe from accidentally starting in reverse unless the toggle is deliberately held down.
Your thoughts?
Alan
Your thoughts?
Alan
