Hi guys! I am a relative newbie, both here on the site and to model engineering. I am interested in the BollAero as a possible first project. I am also looking at the MLA-17 (
http://www.statecollegecentral.com/metallathe/MLA-17.html), another compression ignition (diesel) engine. Its plans come with a 30 page booklet that gives a lot of explanation, which I as a newbie find helpful.. The MLA-17 does not have a contra piston, which seems simpler, but on the other hand it has a threaded backplate, which I am a little afraid of.
It's not real clear from the plans, but as I understand it, the contra piston is a press fit in the top of the cylinder, so that it will stay in place, but still be able to be moved by the compression screw, in order to adjust the size of the compression chamber. Is that correct? It seems that the fit of the contra-piston in the cylinder would therefore have to be very precise, and presumably would have to be lapped to a precise fit. Do I have the concept correct?
Charlie, I hope I am not hijacking your thread by posting this question here. Your pictures and description are great. You make it look easy, and that gives me some encouragement, so I appreciate it.
Also, for Omidn, you should check out this site:
http://www.modelenginenews.org/ If you click on "Resources" in the left column, and look at the "FAQ" and "How To" sections, there is a lot of helpful information, including information on the fuel and how to obtain it.
