Hi Guys,
At a recent steam fair Rich and I each picked up a piece of copper tube that both just shouted-
"Make me into a boiler....pay the man the tenner!"
Its 107mm diameter by 300mm long and the copper is 1.68mm thick. In the chaos that is currently my workshop I cannot find a book that tells me the formula for working out the permissible pressure it can take. Can someone please remind me and if feeling helpful tell me the max pressure. I hope to run it between 50 and a hundred psi but preferable the higher end of the range. It will need a test cert as it will be over the three bar litres and I want it to run a multi-cylinder engine so need steam and pressure available in good quantities.
Also any suggestions for type or style of boiler? It will be static.
Julian
Julian
