Blueprints for slow running steam/compressed air
ksor
I'll try to build a very slow running "motor" where you can "hear" the sound of a well designed engine.
Any links ?
Best regards
KSor, Denmark
Pick just about any engine that has a 1/2 inch to 3/4 inch bore double acting piston and build it well with good fit and finish it should run slow. A well built engine will run on breath power.
Tin
ksor said:
Any links ?
This is a great running and sounding motor worth your consideration.
http://www.homemodelenginemachinist.com/index.php?topic=4761.0
This one is a little more complicated and also runs on one PSI of air pressure, the exhaust sound is reduced with my addition of the muffler on the back
http://www.homemodelenginemachinist.com/index.php?topic=4364.0
With out knowing what your level of experience is... Here's a link to about 50 free plans that may contain a few of interest.
http://groups.yahoo.com/group/Elmers_Engines_1/
-MB
Oh, what nice peaces of work - really ! :bow:
But I think they run too fast - I want something with a big wheel and a piston working in both directions - running 50-100 RPM - and with the sound of compressing and decompressing air/steam.
But I must say you have chousen very very handsome colors - the green and brass I think they look good togather.
Thank you for the compliment!
A beam engine design might be exactly what you are looking for. I built a simple single acting beam and its flywheel RPM is very low compared to the other style engines I have built. Due to its simplicity I built it with out any formal plans.
It's engine #10 in the link below;
http://www.homemodelenginemachinist.com/index.php?topic=4707.0
-MB
Yeah - that's nearby - I'll study the drawings - Oh ... inches ... :(
Anyway - THANKS !
Ksor, I just ran my beam engine and counted the revolutions. It's about 50 to 60 RPM.
I got a little dizzy and lost count a few times! :big:
It's single acting and very slow because the power stroke pushes air UP under the piston, and gravity pulls the piston DOWN.
The pressure can be adjusted so the motor will run even slower, probably slower than any other design of motor.
-MB
Hej Ksor
If this one is slow enough for you, you could visit my website
[ame]http://www.youtube.com/watch?v=a-LAOhWedgw&feature=channel[/ame]
I know it's a kit, and and expensive one! but maybe you mean something like this
[ame=http://www.youtube.com/watch?v=mE9dZmqBF6c]http://www.youtube.com/watch?v=mE9dZmqBF6c[/ame]
Giles
Giles,
I don't think the govenor will work at that speed Rof} WOW that's one beauty :bow: Thm:
Heres my PM Research No1
Tony
I built the engine mentioned by Metal Butcher from Workbench Minatures. Very nice engine and great plans. I didn't think it would run very slowly, so I went out and ran it and I figure it ran about 100/120 rpm
Mark
Very nice engines Gentlemen, :bow: :bow: :bow:
Best Regards
bob
Thanks for the mention MB and two dogs. I just checked mine and figure somewhere between 100-120 rpm's too. You can see some of the mods that others have done to the basic design on the website under customer comments.
Bill
You might try this one of Elmer's Engines.
http://www.john-tom.com/ElmersEngines/50_edu.pdf
It features a unique valve timing that should have it operating quite slowly. Although the dimensions are in inches, I think that the only critical parts to convert are those involved with the cam driven valve.
Alan
