thefishhunter
- May 28, 2009
- 15
- 1
AW SH$%^&%^!
For my first engine, i decide to build Elmer's Fancy. and after looking at the "model of the month" I decide mine should be all shiny, and good looking. So I picked up a 316SS Hexbar and off we go.
Well 40 hours later I got all the parts built with the exception of the base, and the two air ports in the post.... I assembled everything, chucked it up in the drill, make it go roundy round and up and down....
Smooth as mammary skin. So let get this thing hooked up to air.
So now to drill the two air ports. Using my lathe cross slide as a drill press base I got the first stopped 1/16" hole drilled, and managed to break the drill bit off 3/4 of the way thru the drillthru feature.
HOW DO YOU REMOVE A 1/16" DRILLBIT FROM A HOLE?
