I am bulding my first stirling engine and I am wondering how the shaft is supposed to fit into the bearings. The plans call for a .250 diameter drive shaft (the .250 is an open dimension - it actually says .250 Stock). So, I bought a piece of .250 dia. stainless that actually measures .249 dia. The ID of the bearing is .2475 dia. Will this be alright or will I need to turn another shaft that I can press fit the bearings onto? I am thinkning that maybe the weight of the flywheel is enough to allow the bearings to turn with the shaft instead of the shaft turning inside the bearing (I think I said that right). Any thoughts on this would greatly appreciated.
