My plans call for a shaft with a 5mm diameter. The carrier the bearing sets in also has a diameter of 5mm. A 11 X 5/4 bearing is spec'd.
Is the following correct about bearings?
11 = the diameter the bearing will fit in
5 = the diameter the shaft/axle should be
4 = the width of the bearing
Thanks!
Your zero experience friend
Thanks!
