Hi All. I've got this "Heat Experiment" going on. I need a wick for my alcohol lamp. I've tried nylon twine - it melted. No big surprise. Then I got some cotton rope. Seemed to work OK but burns up real fast, and smells bad when it smolders. I got some replacement wicks for oil lamps at Wally's, this morning. Had to split them lengthwise to get them into my ferrule, which is a .22 cal shell casing drilled thru and soldered into a copper fitting. What do you fellas use for a wick? Also, I used 91% isopropyl alcohol, seems to leave a lot of black soot on the glass tubing? I've ran a search here for alcohol lamps, but did not find the answers I needed. Thanks in advance for any help. Here's a short vid of what I got going on. Still needs some work, it doesn't run consistently. I would like to make a better trunnion for the tube, when I get more time, of course. :big: I believe this is my bookmarked page where I found "the Plans" :
http://www.bekkoame.ne.jp/~khirata/indexe.htm
And now without further ado:
Edit: Sorry, my Photobucket link is B.O. I will try to fix it up ASAP (tomorrow)
Thanks again for the help,
Davyboy
Davyboy
