Air Compressor Plans
Discussion in 'Plans' started by Royal Viking, Jan 25, 2018.
Help Support HMEM by donating using the link above.
  1. Jan 25, 2018 #1
    Royal Viking
    Royal Viking
    Royal Viking
    Apr 17, 2010
    115
    0
    I am looking for plans to make a 12vdc motor driven air compressor. The small tire inflators don't last very long. I was thinking if I made one it might last longer. Any ideas or suggestions?
  2. Jan 25, 2018 #2
    ODgreenK5
    ODgreenK5
    ODgreenK5
    Dec 15, 2017
    9
    3
  3. Feb 19, 2018 #3
    Royal Viking
    Royal Viking
    Royal Viking
    Apr 17, 2010
    115
    0
    It looks interesting. I'm not sure my abilities are there yet. His one way check valves solve that problem for me.
    I have a weed wacker engine that I was thinking I could adapt to an air pump. I'd need some way to add oil to keep things from seizing up.
  4. Feb 19, 2018 #4
    JCSteam
    JCSteam
    JCSteam
    Nov 30, 2016
    357
    61
    I had this thought a while back to to run steam engines from. My idea was to have a pulley driven from my layshaft driving a twin cylinder setup. I look forward to seeing what suggestions for plans are out there. I looked at what I could build and they all showed large (too big for me) ait compressors rigged up to electric motors, so not what I was after.
  5. Feb 20, 2018 #5
    10K Pete
    10K Pete
    10K Pete
    Jan 25, 2009
    527
    118
    Just build one. It's nothing but a piston engine with a different head. Reed valves are very easy, but caged disc valves aren't much harder and way better than reed valves for longevity.
    Have a go!
    Pete
  6. Feb 20, 2018 #6
    WSMkid
    WSMkid
    WSMkid
    Sep 26, 2012
    79
    14
    Pete,
    Do you have and pictures of your build?
    GJ
  7. Feb 20, 2018 #7
    JCSteam
    JCSteam
    JCSteam
    Nov 30, 2016
    357
    61
    I googled reed valves, as I wasn't sure what they were, but they seem to be an very easy device to make, my only concern is wether they may get too hot and become sticky if made from plasticard, would this material be ok to use or does it require something else? Rubber maybe?
  8. Feb 20, 2018 #8
    deverett
    deverett
    deverett
    deverett
    Sep 6, 2007
    979
    170
    Stuart used to do castings for a twin cylinder compressor but they are not listed now. If you ask around, you never know your luck and someone may have the drawings.
    The Emerald Isle
  9. Feb 20, 2018 #9
    10K Pete
    10K Pete
    10K Pete
    Jan 25, 2009
    527
    118
    Spring tempered steel is the reed valve of choice.
    Pete
    JCSteam likes this.
  10. Feb 20, 2018 #10
    10K Pete
    10K Pete
    10K Pete
    Jan 25, 2009
    527
    118
    Most compressors have a closed crankcase and either splash oiled lower end or for larger units a pump and pressurized oil. A weed wacker engine would be hard because it's a two cycle and probably has some porting cut into the side of the cylinder. 4 cycle would be better.... ???
    Pete
    JCSteam likes this.
  11. Feb 21, 2018 #11
    Cogsy
    Cogsy
    Cogsy
    Jul 30, 2012
    2,029
    571
    Gender:
    Male
    Probably even easier is to go to an auto wreckers/breakers yard and buy an old automotive air conditioner compressor? If you get the old type with oil bath bottom end they last for ages and pump a lot of air. The only modification needed is to eliminate the electric clutch that disengages the unit when the aircon is switched off.
    10K Pete likes this.
  12. Feb 22, 2018 #12
    Royal Viking
    Royal Viking
    Royal Viking
    Apr 17, 2010
    115
    0
    Thank you for the suggestions. What I am looking for is something portable that is powered off of 12VDC. So smaller size, can hook up to battery from jumper style clips (unless I can find something that can turn without blowing fuses on the power sockets), and won't wear out in a year like the cheap ones.
Share This Page
