I have used an adjustable boring head several times with good results although my approach seems a bit clumsy. Basically I usually rough the hole undersize with a drill or other means. Then I adjust the boring head to clean up the hole (hopefully still undersize). I measure the hole and from that measurement determine how much larger to adjust the head in one or several steps to get to the diameter that I'm after. I use a similar approach with a boring bar in the lathe as well. Seems like there should be a more "scientific" way to get the setting, but I'm not able to think of one that isn't a lot more trouble than what I described above. Any comments/recommendations?
