Adding a QCTP
Teza
Hi Guys,
I bought a QCTP on eBay for my lathe, some small mods to the "T" nut saw it fitted.
Decided I needed a better way change the angle instead of a shifter on the large hex nut, turned and threaded a some 5/8" round for a handle then onto the shaper to cut some flats for a spanner
Some 1" bored and threaded for the ball handles
Generated co-ordinates to incremental cut the balls
Start the incremental cut
Then the other half
Cleaned up and ready to go
All the bits together
Done, MUCH better Thm:
Cheers Terry
Nice balls :big:
Gee, that incremental cut sheet looks very familiar.
It's nice to see someone using the program.
Nice work on the QCTP!
Marv, do you have a link to that program? I have one that works similarly, but the output from the one in the picture looks better than mine.
For those who hesitate to use that method - it DOES work, and works very well, for making decorative balls like this. One technique I like is to ink or dykem up the ball after the roughing op, and then, when you file it out, the ink at the bottom of the grooves stands out well and in the end, makes up for a more accurate ball.
The URL for my page is in my sig. The name of the program is BALLCUT. Click on the name to download.
Nice work!
I'll be doing the T nut thing shortly....probably changes the handles too......but perhaps I'll make two sets for both lathes
I have the same looking QCTP and machined down the thickness of the plate to get it to fit in the thin hafco slot but it ended up bending. I machined the QCTP body and also some off the hafco post and made them fit. It was much strong and got rid of a intermittent chatter issue. Your balls look great, now you have to make them for the rest of the lathe.
Brock
Marv, I don't want to hijack this thread, but I am going to take this opportunity to thank you for creating the ballcut program as well as the others that you have written and so generously shared. I have used the ballcut program several times for ball shaped knobs, and once to fashion a very special ball and socket joint for a tractor part that was no longer available. I have used some of your other programs as well, and find them to be quite useful. Once again, THANK YOU!!
Thanks for the kind words, Terry. It's really nice to know that the programs are reaching the people to whom they were directed.
I know this is a slightly old thread (2months) but it's recent enough. How do you go about making the Lock for the tool post? i.e the top threaded cylinder that locks the tool post from rotating; do you wait to tighten the post before you drill and tap the blind hole for the handle?
I'm planning on making my own QCTP and i don't want the handle to end up over the work piece when tightened. This may be obvious, but i haven't seen any specifics on it.
Thanks,
Ian
Either just that, or drill and tap the hole rougly in position and then take light skims off the bottom of the nut until the handle comes to where you want it.
Hi Ian,
With this one I took the handle back out and turned a few thou off the bottom ( trial and error scratch.gif ) till it tightened where I was happy with it ;D
Terry
Tighten the handle, decide how many more degrees you want the handle to rotate - let say the handle is pointing to 12 O'clock straight over the bed - and you want it at 4 O'clock - thats a further 120° (30° per hour for estimating purposes).
Now multiply your thread pitch by 120/360 x 1.5mm pitch (say) = 0.5mm
That's how much you have to machine off the bottom or the washer.
In the above example - if you were at 6 O'clock and wanted to get to 4 O'clock then either you have to make a new washer 0.25mm thicker or reduce by 1.25mm .... and so on...
Sorry if I'm stating the obvious.
Ken
Wow; never thought of that. I guess the only concern then is to make sure the tapped hole is deep enough, and that there is enough material to be able to shave off without going too thin.
The "bottom" is the part of the cylinder that touches the TOP of the dove tailed block.
_
________ //
/_________\'/
| | ^_____Here right?
_________________
|_____|____|_____|
Thanks,
Ian
Correct - sometimes there is a washer and you can (optionally) play with that instead.
Ken
