Tin Falcon
- Jul 9, 2007
- 7,207
- 788
Some of you may know last summer I purchased a used grizzly 9x20 lathe. It sat in my shed for about a year . After realizing it was unlikely to actually get used out there. It was moved to my basement with my sons help. And I finally got to add the QCTP i picked up at cabin fever from LMS.
I looked at Steve Bedairs site for Ideas. there are several ways folks have done this mod. When I had the AXA on my mini lathe I machined and tapped a bolt to make an extension/adapter. That was one option. I was considering a trip to the hardware store to pick up a 14MM tap and just drill and tap the compound . then I cam across a 1/2 20 tap and die and said why not so I turned down the stud that comes with the QCTP and threaded to 1/2 -20 then drilled and tapped the compound.
