Y
yeorgjx
Guest
I wanted to make (and made) an ER11 chuck.
This topic helped a lot (thanks) http://www.homemodelenginemachinist.com/index.php?topic=11328.msg163528#msg163528
The problem was that my lathe didn't show 0.75 on the thread instructions.
I saw that as greater number of teeth in pinion A bigger the size of the pitch to be machined.
I also noticed that for step 1.5 was needed same number of teeth on the gears A and D.
So I had to use the 1/2 amount of the teeth of pinion D for pinion A.
The solution (based on the gears I already had) was A 30,B-C 35 and D 60.
Maybe the Chinese did not indicate because the 0.75 can hardly be matched ...(third photo)
