4 Jaw chuck
Noitoen
I was given e Belflex Spanish/Chinese lathe and it only had a 125mm 3 jaw chuck. Today I made a back plate to install an old 125mm 4 jaw I had.
The spindle nose on the lathe is a modified DIN 55027 size 3 type, being the only difference, the taper which, on my lathe, it's parallel.
Turning the the back side.
Tapping the fixing holes.
Had to make an extension to the tool holder due to the fact that the lead screw's protection, the tool post doesn't reach the adapter plate to true it up.
Counter sinking the chuck mount holes.
Ready to test.
Finish:
Adapter plate drawing.
Belflex.pdf
View attachment Belflex.pdf
The spindle nose has 3 21mm holes with a moving plate behind. This plate has a type of key hole that slide underneath the chuck's nuts to release. Just untighten the a little, rotate the plate and remove the chuck.
