Gordon
- Jan 4, 2011
- 1,332
- 343
I thought about O rings but the engine runs hot so O rings may be short lived. Also there is more friction with O rings and as marginal as this engine is the additional friction may be too much.This engine might be a perfect candidate for O-rings. Then you won't have to worry about the sealing side of a ring groove or poor ring construction etc. etc. etc.
How about that??
The pistons are basically the same for O-rings. Just a properly sized grooves for the chosen ring. Maybe the piston grooves you have already can be modified for O-rings.
In any case, any compression you feel once the pistons are past the spark plug hole is a moot point. It does you no good. Normally in that phase the pressure from ignition would (hopefully) be pushing the pistons to the right. Sort of like how you feel suction on the power stroke of a conventional engine when you turn it by hand because the valves are still closed and there was no previous ignition / expansion to push the pistons down.
Basically the LH piston is just a a cylinder head but movement is required because it also draws in the fuel mixture.
