O rings as piston rings
neil_1821
I have seen this used quite a bit, especially on steam models, but I’ve been struggling to get my hoglet started and a friend diagnosed it as being down on compression, believed the pistons were perhaps too small and the O rings weren’t sealing properly. Question is, how tight a fit should they be on the cylinders? I figure too much and the ring will bind causing it to tear and too little it doesn’t give a good enough seal.
Ah that’s excellent info, thanks for the link! Judging from some responses I don’t have anywhere near enough compression on my hoglet. I’ll be re-machining some new pistons!
I have never used o rings in an ICE but if I did I wouldn't use anything less than viton.
"I have never used o rings in an ICE but if I did I wouldn't use anything less than viton."
I can make the same statement with the caveat that of several ic engines (mor'n a dozen) I used viton o' rings on three 'Henry Ford first Engine'. I don't run them all that much but when I do they run very well. I used the standard fit tables.
http://www.applerubber.com/oring-gland-calculator/
Ray M
Cheers Ray, that will be very handy when I get the hoglet back! Need to go scrounge some aluminium now :)
Why not put a light shim under the o ring to tighten it up , save you making a new piston.
Vince
I had thought about shimming it out, but I want to measure the pistons again just to check they’re not undersized. I think it may also depend on how much they’d need shimming but it’s worth experimenting with.
