zeeprogrammer
- Mar 14, 2009
- 3,362
- 13
Using my X2 mini-mill, I did a flycutting operation.
I believe I wrongly had it in the high speed range.
I have the belt drive conversion.
I was taking relatively light cuts...maybe 5 thou. Maybe 10 at most. (Or thought so.)
Aside from the motor stalling several times, I noticed the spindle got hot as well as the motor. Later I was using an end-mill but didn't notice the heat. However, I wasn't running it as long as the flycutter.
I also noticed the flycutting tool wasn't the sharpest and things improved when I honed it some.
The part I was cutting is smaller than the diameter of the flycutting arc. So a lot of interrupted cutting was going on.
One last thing...there are 4 screws used to mount the motor. I had to replace one of them with a slightly longer screw. I can't imagine the screw would come up against anything rotating that would result in friction.
I'm going to keep an eye on it...but if anyone has some thoughts or suggestions...I'd appreciate it.
