I fitted the scale I bought last week over the past couple of days.
Rather than show every pic,I refer you to the photobucket album:
http://smg.photobucket.com/albums/v401/bramleynz/x-axis digital scale/
You will note I took the lazy way out,and fitted the scale to the t-slot normally used by the table stops.I never used them anyway,so this was the simplest way to go about it.
If I hadn't had that slot available,I would have fitted the scale at the back of the table,to make it less vulnerable,and because the cord between the reader head and the display unit isn't overly long.
Only one little problem cropped up.While I was fiddling with making the mounting plate for the reader head,one of the captive nuts fell out.I took the back off the unit,but still couldn't access the place where the nut lived.So I pushed the nut back in with a tiny screwdriver ,and once in place,applied a smidgeon of superglue to the outside rim of the nut with a pin.
Job done.Almost.I just scraped my hand on the corner of the ally angle I used as a protective cover.A bit of filing off the corner is called for.
Any comments,good or bad,invited.
