ShedBoy
Senior Member
- May 13, 2011
- 792
- 34
My skills are not to the point whre I should be building small IC engines yet so I have decided to work up to it. Looking through the many plans I have downloaded I found a scanned copy from the book my metalwork teacher had when I was in high school 20 years ago of the first engine I built and lost somewhere. I think I got it from the mcabe site, it is called a Wells Stationary. I am making some small changes to make it look a bit pretty. The plans call for a cast or folded sheet main support but I had some ali thick enough to make the cast part, billet I suppose they call it.
Sawing 32mm ali is not a fun job, really need to make and arbor for a saw blade for the mill
Squaring up using a broaching drill I found. Need to make a flycutter too, but this worked quite well
A bit of shaping and marking out
Half done just need to make it flow nice around the main bearing area
That was the end of day one, other things on that day.
Brock
Brock
