Has anyone else tried this engine with a glow plug? It just might be that the internal layout of the cylinder head won't allow it to run for any length of time.
It might be that the direction of the fuel entry is straight onto the glow tip, in which case, once the engine started to fire and run, the fuel hitting it just might put it out, no matter how much battery power you feed to it.
My dealings have always been that the temp and compression in the cylinder has to be enough to keep the platinum wire glowing thru a catalytic process after the battery is disconnected.
Some of my glow engines required them to run for a while before that critical moment is reached, otherwise the charge of cold fuel going in extinguished the glow.
Have you tried a higher nitro mix, or a plug with a heat bar across the tip to try to retain some heat, or a shorter plug, so that it doesn't protrude into the cylinder so much, to try to protect the glo tip from any cooling fuel?
Try a 5% mix of petrol in the fuel, that was used as an old trick when nitro wasn't available over here. Don't mix up a whole batch, just say 1/4 of a tank, just in case it doesn't work for you.
If glo plug running hasn't been done before, then you have no means of knowing what will eventually be required to get it to run, if ever.
Bogs
