- Mar 3, 2008
- 243
- 20
Well this is not about engines, but I found these plans a while ago and knew I would build it some day, It is so interesting.
Something that you inject compressed air into and out one end comes cold air and hot out of the other, has to be investigated
Here is a link to the story and plans: http://www.visi.com/~darus/hilsch/
There are some practical uses for these like cooling cutting bits and cabinets: http://www.airtxinternational.com/how_vortex_tubes_work.php
I have done some tests on it and it does work. It certainly won't freeze mercury or cook my breakfast ( as the article states). The cold pipe is cold to the touch and warm for the hot pipe. I have to do some experiments with different hole sizes in the washer next.
Here are some pictures:
The cold end
The hot end with adjusting valve
All the parts before assembly
The Spiral. This was the tricky part, I pierced it out with a jewellery saw and finished it up with a file.
This shows the washer on the spiral chamber
On to the next project.
IronHorse
The cold end
IronHorse
