zeusrekning
- Dec 21, 2007
- 448
- 0
I didn't want to hijack Bretk's post so here we go.
This is the little info I have on vibratory finishing AKA tumbling.
We would use a two step process when polishing alum.
At my last job we used plastic media(slightly abrasive but nothing like ceramic) to smooth out the part. Then we would finish tumble using a porcelain media to get a good polish. We also used two liquid compounds for this process. The first used with the plastic media was like a cleaner/degreaser. It would keep the pores of the media clean and keep it "cutting". The compound for the porcelain media (which looked like white rat droppings) worked the exact opposite way. It would actually keep the pores loaded up so not to cut but burnish. Vibratory finishing is not one of those things you can just plug in and go. Well you can but won't usually get good results. But if you do a little research and get the right compounds/media.It works well. I don't know that you will get as good of results as hand polishing but close and a lot easier if you are doing anything of quantity. Check out this link for a little info on vibratory finishing.
http://www.masfinishing.com/Media.html The owner is a vibratory whiz. It really is amazing all the little details that affect the outcome.
Tim
Tim
