Hi, its me again...
Started to build a small two cylinder engine after a plan from a german steam book:
http://www.amazon.de/dp/3788306564/?tag=skimlinks_replacement-20
The plans call mainly for brass as material, but i am going for steel and cast iron, using brass and bronce only where necessary..also, I don't use ball bearings...i prefer plain bronce bearings.
Progress so far:
Base and bearing mounts:
Cylinderblock (cast iron) and zylinder liners (spherical cast iron)
Cylinderblock with the steam chests (also made from cast iron) fittet, the sliding valce is made of bronce.
The steam inletts and the nearly finished crankshaft:
Finished excentric Straps, with bronce bearings fitted:
The excentric Straps fitted to the machine:
Yesterday I started with the conrods, again cast iron:
Did i mention, that I love cast iron?
greetings
Stefan
Progress so far:
greetings
Stefan
