- Jan 19, 2010
- 1,193
- 41
I am seriously thinking about starting work on the "Tiny IC" designed by Arv. (PutPutMan)
The gears specify to be 48 DP but I am not sure which pressure angle to use. 14.5 degree or 20 degree.
I have found some involute cutters in 14.5 and I also found a gear hob in both pressure angles.
here is the link to it
http://www.gearprosinc.com/catalog/index.php?main_page=product_info&products_id=55&cPath=3_4
I have a few questions about using the hob.
1. How do I know how deep to make the cut.
2. Does this type of hob automaticly move the blank, or do I use an indexer?
3. For light cuts do I have to make an arbor with a keyway?
4. I assume the gear hob replaces the set of 8 involute cutters, right?
In my head the hob is the way to go, but is there any disadvantages to it.
Kel
Kel
