JCSteam
- Nov 30, 2016
- 472
- 130
Hi, can anyone give me some ideas on making Tee nuts for the lathe and faceplate.
I'm thinking to start with a square piece of steel in the chuck the same dimension as the width of the tee at the widest point. Then machine of the two mating faces that will run in the grooves, by holding the steel length ways in the 4 jaw.
Then turn the steel rectangle parralel to the bed to reduce to a round shaft that will fit into the narrower section in the tee grooves. Then just turn the rest to a suitable size for the thread I'll use.
I'm just working on the theory of making tooling at the moment so no measurements as this will be measured from the ML4 lathe. I was going to use a metric thread M8 or M10 which ever is closer to the final diameter of the narrower grooves in the cross slide. But I'm wondering if there's a better thread like BSW that would enable me to nip it up quicker with less turning of the spanner?
