zeeprogrammer
- Mar 14, 2009
- 3,362
- 13
Hi,
I'm trying to (not improve) but learn some basic skills. So I thought I'd have a go at making the machinist clamp in 'The Home Machinist's Handbook'.
Not my first attempt at cutting metal...I've made two machinist jacks and the brass mallet (with my own alum handle) from the book....and have made 'good' progress on a Model 2A osc engine...ah...but that's about it.
Anyway...back to the clamp...1/4-20 thread using a die on the screws and 1/4-20 tap on the clamps. Both die and tap from same (cheap) kit. The screw binds pretty badly. I've re-tapped and re-threaded, but as expected, little difference. I'm down to sanding the screws and have made good progress. Some binding left and I think I can get that out before the threads are gone.
I don't think the screws are bad. I tried a couple of 1/4-20 nuts...one goes on slick as a whistle while the other tends to bind a little.
Your thoughts would be appreciated...maybe it's just a cheap tap and die kit? The tap handle is certainly for crap.
Material is free machining steel.
And by the way...just how slick is a whistle?
Thanks.
Thanks.
