TheDogofWar
- Oct 7, 2009
- 5
- 0
This is my basic design idea for my first build, the rendering could be better but I've only got autocad map to work with. The proposed materials are oak and copper. I've chosen these materials because they are easy to work with for my lack of tools and also provide a bit of visual appeal.
First off, can someone point me towards some formulas for calculating proper cylinder volumes and stroke/volume data? Do the diplacement and power pistons have the same stroke?
The displacement cylinder right now is 1.25" ID and 4" long using a about a 1"x3" aluminum piston and the plan was to drive this off a tealight or alcohol burner. The power cylinder has an ID of .5" @ 1.5" in length.
I added the wood strip around the middle of the displacement cylinder as a thermal break, I was concerned that too much of the heat would be transferred through the copper, do you think that would even be a concern?
Opinions, suggestions, concerns?
