J JimN Well-Known Member Joined Sep 2, 2009 Messages 103 Reaction score 2 Oct 11, 2009 #1 A quick question, can I soft solder stainless shaft to the counter weights I have made in plain mill steel? thanks Jim
K Kermit Guest Oct 11, 2009 #2 You might have some trouble with the stainless. Acid flux is needed when soldering that stuff. Don't even bother if it a rosin based flux. Then you'll have to clean it really well so the plain steel doens't turn to rust from left over flux.
doc1955 Gone Joined Aug 26, 2009 Messages 1,261 Reaction score 164 Oct 11, 2009 #3 Your better off silver soldering in my opinion.
J JimN Well-Known Member Joined Sep 2, 2009 Messages 103 Reaction score 2 Oct 11, 2009 #4 Thanks, was not sure about soft solder or silver solder. Since I have silver solder here will use it. thanks again Jim
