[SIZE=+2]SIMPLE FILE GUIDE - A VERSION FOR QUICK CHANGE TOOL POSTS[/SIZE]
Since I now have a QCTP and greatly appreciate its convenience, I get unreasonably annoyed when I have to take it off to remount my old monotool holder because I need to use an old tool for which I haven't yet made a QCTP holder. In particular I had to do this to use the Simple File Guide (see [thread]18274[/thread]) in order to make the hex section of some special nuts. So I decided that the following day I would make a holder for the File Guide.
As often happens the night brought council. Rather than simply make a holder for the existing File Guide it would be better redesign the guide so that the distance between the file and the lathe axis was adjusted by the QCTP's ability to move a holder up and down the dovetail. The result can be seen in the photo below, where the new QCTP version of the Simple File Guide is seen helping to make it's own lock nut.
Unlike the original design, the file is always horizontal. This has the advantage that the File Guide can be removed from the tool post without losing the setting of the distance of the file from the lathe axis.
As in normal QCTP holders, this height is regulated by adjusting the height wheel and associated locknut. However with respect to normal tool holders this File Guide has a much more robust height screw (diameter 8mm instead of 5mm) and the wheel has graduation marks around its rim to help with adjusting the height of the file. The thread on the height screw has a 1mm pitch so one turn of the height wheel moves the file by 1mm. The resolution of the graduation marks is 0.02mm.
Note that the height reading from the wheel is not absolute - the graduations are used to move the file up or down by a precise amount.
For example suppose we want to make a hex section with 13mm across the flats.
- Turn the part to have a diameter of 1.1547 x 13 = 15.01mm (diameter across the vertices).
- Set up your indexing method (gear train or whatever) so that you can position the part correctly for each of the six faces.
- Mount the File Guide on the QCTP and set its height so that the file just touches the part.
- Use the height wheel graduations to drop the file by half of the difference (in this case almost exactly 1 mm)
- Position and then file each of the six faces.
