- Jan 4, 2011
- 1,334
- 344
I have built Rudy K Stirling engine and I am having a problem getting it to run. I have read the thread about getting a Stirling to run the first time and several other articles and threads. The flywheel turns easily and the piston slides freely and stays in the cylinder if I plug the end when it is held vertically. If I put 10 psi on the system there are no leaks. There is a soap bubble every 5 seconds or so around the guide on the displacer cylinder and if I make it any tighter it binds up. If I fire it up with an alcohol flame it runs for probably 10-15 revolutions and stops. More heat does not seem to make it run any better. The flywheel seems to be rather large and heavy for such a low powered engine. Before I start lightening the flywheel has anyone else had experience with this engine?
Any suggestions welcome.
Gordon
Gordon
