- Mar 1, 2010
- 865
- 82
You may see in some of my posts reference to a Simplex I've purchased to refurbish. From what I can tell it hasn't been run for 10 years and I bought it knowing it needed some work doing. That said the boiler has been both hydraulic and steam tested and given the OK by club boiler inspectors. I'll get it formally certified once I've re-built it.
My question
The cylinders are cast iron with cast iron pistons and graphited packing. The bores are in sorry state with a bit of rust and old steam oil. As it is a Simplex with 1.5" bores I am thinking of boring it out the extra 1/16" to Super Simplex dimensions of 1-9/16" remaking the pistons and rods and fitting proper rings. I need to remake the pistons and rods as the cross heads are shot as well and the hole for pin through the rod is oversize.
So should I do what I'm planning or just try and hone out the bores and make gunmetal pistons and use viton rings. Or do something else?
Pete
My question
Pete
