Plans & Designs - Symbols?
JimM
Hi all
Has anyone got any good links to sites that explain what the various symbols used on engineering plans and designs mean.
Specifically, I've got a couple of the 'Workshop Practice' books and on turned and bored parts they often have 2 symbols on the plan....
The first is 2 circles, one inside of the other
The second is what looks like a small bung or cork (like those use to plug test tubes)
I'm guessing one of the symbols means that the bore should be concentric but after that I'm stuck. :(
Any pointers much appreciated
Jim
That's the Projection Angle symbol. It shows you which way parts are flipped on a three-view drawing.
Basically, parts are either "tumbled" or "scooted" around on the page... I'd say that "Third Angle", or what I called "Scooted" is the more common. ;D
Jim,
An explanation of the difference between the two.
Hope it helps. ???
Best Regards
