I am finishing the set up of my new 7 X 14 lathe and have an adjustment issue I am wrestling with. It involves installing and adjusting the compound on the bed.
I loosen the two brackets on the bottom of the compound (with the 3 hex head screws on each) and slide the compound onto the bed. I can then snug up the the screws on the backside bracket without any problem, but when I snug the front bracket screws, the compound binds and won't move on the bed. If I loosen the screws on the front bracket, it then moves fine, so obviously I have some binding going on.
The gibs screws on top of the compound are fully backed off, so they aren't causing the problem. Am I doing something wrong here, or is this something that often happens? I can probably shim the front bracket with some spring steel and tighten down the screws and then adjust the compound with the gibs screws, but I would like to know that there isn't any other option first (or at least be assured that my idea is OK).
Thoughts?
Jeff
Thoughts?
Jeff
