Hi Abby,
thanks for the interest and offer of supply of gunmetal items. I am interested in you supplying the items. It may be a fruitless exercise because shipping costs outweigh the material costs to make it a viable option but if you are willing to give me a total cost for delivery to Adelaide South Australia I shall give it my keeness attention.
I have included pictures of a steel version I made to test the efficacy of the design and to ensure that I am able to construct them within the capabilities that I have. My design is based on having no milling capability and all machining is undertaken on the lathe.
The design is based on a machined cylinder, having a face machined on its length to accomodate a valve chest type construction silver soldered to it. Within this item there are two webs to isolate the two steam inlet ports from the exhaust port. Then the valve chest proper affixed to it and between these two items is a flat plate which carries apertures for the steam inlet ports and exhaust port. The slide valve is a standard design but because I cannot mill the porting recess underneath I have to make it in two pieces silver soldered together.
I can obtain round gunmetal in Australia so if you wish to not consider the supply of material for making the cylinders, covers and pistons then concentrate on the flat material only. Since you indicated some casting capability you can provide them as a casting or as bar that I can machine to size and assemble. Obviously the webs cannot be easily included in the casting they are made separately and silver soldered in. The flat plates 1/8th" thick are are not easily cast, so I recommend that you supply a bar of sufficient thickness to enable three plates to be cut from it and machined, also material for the lower half of the slide valve, say at least a piece 3/4" thick.
It is for two sets of each.
Thanks in advance.
Brian
PS hope the pictures are attached on post, there not showing on preview.
