SignalFailure
- Jan 1, 2008
- 366
- 3
I made a simplified version of Elmer's 'Scotty' a month or so back but it refuses to run on air (aquarium pump) or steam (tiny pot boiler giving about 30 psi). The whole thing gets very very hot on steam and seizes up, I made the cylider of cast iron and the piston brass.
On air it "almost goes" - maybe a revolution or two but doesn't seem keen on making the return stroke. I took care to make this one as accurately as possible (I think it's my most accurate yet) and it turns over silky smooth when tweaked.
When part dis-assembled I can tell that air is getting to the cylinder via the rotary valve/crank fine and air is exhausing properly via the hole at the end of the crank.
When I apply liberal quantities of oil I can see it bubbling around the junction of the flywheel/bearing and crank-web/bearing but sufficient air seems to make it to the cylinder.
The piston rod runs very freely through the bracket (excuse unfinished state!).
My question (finally!!), has anyone who has built one of these got any tips to get me running? Is there any way to form a better seal at each end of the bearing? Might slimming down the yoke or thinning the centre of the flywheel help?
Any suggestions greatfully received - I'm eager to build a scaled up version if I can get this one going!
Here's the engine for reference (hope posting of images is ok in this section!)
