vederstein
Must do dumb things....
- Feb 26, 2011
- 918
- 745
I've been working on this on and off for months and I think I finally got it to work.
It's a routine for NGCGUI that creates a slot with two different radii. This is much more powerful than the sample "Slot" routine supplied with NGCGUI for LinuxCNC. This shape is seen time and time again, particularly for cranks and offset handles. You can also use it to replace the slot routine (make R1 and R2 the same).
R1 or R2 can be any size. The angle between them can be anything. It will offset the endmill inside or outside of the contour (depending if the endmill diameter is positive or negative).
The routine will fail is the arcs are too close (e.g. the line segments cannot be created) or one arc encompasses another arc. But that's different shape. (strangely it will create a circle if the two arcs are exactly the same size and position).
It's a non-sensical combination, but it will also fail and/or do funky things if the the endmill diameter is both negative and larger than one of the radii.
If a couple of people could please test it and let me know if you find any bugs, I'd appreciate it.
Also note, this routine is used at your own risk. If something goes bad, I am not liable for anything.
View attachment teardrop.zip
