Quantcast
newcomer
Help Support HMEM:
JimB
New Member
Bedfored UK
Hi all,
I hope this is an appropriate site for my needs, I am NOT an engine modeller but I do utilise many of the skills and processes that you use...
I am hoping to get some help regarding my Myford super7, I have been using it for about 40 years, I had my first myford in about 1960.
I have not needed to cut a thread since around 1985 and have lost the table of cog settings for lead screw speed setup!! I am sure it must be available without getting a new myford handbook.
Thanks and best wishes
JimB
goldstar31
Twixt Tyne and Tees
JimB
Welcome from Newcastle upon Tyne.
You can get a copy of the Super7 manual from the internet. Simply google Myford Super7 Manual pdf and see what happens:)
However, if I have a few marbles left, the ratios should be on a card INSIDE the cover.
Let us know please
Norman
JimB
New Member
Bedfored UK
Thanks Norman,
Sure enough, I printed the chart, (page 32, not in the back as I remember).)
I have only just realised that when I last moved the machine I restricted access to the motor end and no longer have "EASY" access to the gear change.
My workshop is 20' by 12' and with a bit of help from my son, ( a good engineer how hopes to inherit it) we will move the lathe to be beside the Vertical Miller.
Thanks again
JimB
