Do what you can, with what you have, where you are.
Theodore Roosevelt
The time has come the Walrus said, ya he forgot however about the bride who lacks mechanical understanding. So after replacing the clutch in her car again . . . time to start teasing a flywheel out of some stock.
I can see it hiding in there, three tapered spokes, its just how the heck am I gonna get it out. First thing I suppose is to establish some reference points that regardless of how many times I end up fiddling with the stock I can always return to a known state.
So I stare at it and decide I need these three points that i can index to, one set each side. OK, now as I do not have a RT how to evenly space the desired points went thru many incantations mostly ending in Nope thats a waste. Hand lay them out, not gonna happen for me, be a mile plus a block off that way. So the DUH came to mind and a quick wip up returned the following gizmo. . . . . . . . . . Chuckles over
Then saw blades are cheap and accurately cut. A simple spindle and some double stick tape to hold the stock to the blade gives me the poor mans version of a round de round measuring device. Blade is 24 teeth so with a drop pin engaging one tooth the first of my future reference points is located. Turn blade 8 teeth and do the next mark. One more and this side is done.
To do the other side, removed stock and spotted holes in the saw same as the blank stock. set a small ball bearing at each point, replaced stock setting the previous little divit holes over the ball bearings, secured it down just enough oomph to maintain position with a short hunk of stock and bolt in spindle (not shown) spot drilled the other three and now I have evenly spaced points of reference on both sides of the future flywheel.
Figure that whatever error is inherient to the saw tooth spacing will be reduced, is reduced as one gets closer to the center of rotation. Something like that.
So, step one is done and I'm working this out with AL before trying it on brass. Time will tell if stone axes and flint knives will do this job or not
Theodore Roosevelt
