student123
- Oct 31, 2009
- 183
- 0
Doing my first engine, Dave Goodfellows brassy babe:
http://www.davegoodfellow.com/plans.pdf
Mine's been rechristened brassy madam. New to engines also.
I've followed the plans & located the pin linking piston to crank 1.05" from base of piston. If you do the algebra on the plans , the hole on the crank disc (which the pin goes into) should be 0.2" from the centre
Above is a pic of where the brassy madam build is at - the piston is at its lowest.
However , in the pic the link pin is virtually at to the centre of the crank disc
Am I right in assuming at the bottom end of the stroke, the piston wil be vertical & the conncing pin at its lowest point?
If yes, it looks like I need to relocate the connecting pin. Theres a pencilmark in the pic 0.2" from the centre of the crank disc -am I right in relocating the pin to align with that pencil mark (ie move the pin approx 0.2" down?
Thanks in advance
Thanks in advance
