hammers-n-nails
- Mar 22, 2009
- 206
- 0
Im in the process of figuring out the valve for the traction engine and am trying to figure out how much compression i need if i have about 20.75pounds of reciperating mass(this is an educated guess at this point) and an average piston speed of 3.46fps and a piston area of 15.9 sq.in. how much pressure would i need to counter the pistons movement? im having trouble figuring out how much force the parts have at the end of the stroke, i know all the variables but i cant figure out how to use the equation (i think) i come up with 2.23lbs-force and i dont see how that could possibly be right. the equation i have is F=m(mass? 20lbs)xa(acceleration? 3.46fps) / 34.17(acceleration of gravity)=2.23. if i convert everything to metric and find the newons then convert back to pounds-force i get exactally the same thing. what am i missing? theres no way i only need .14 psi compression. please help im a carpenter not an engineer.
