......Your feet! Yep, Longboy knows! (size 13's). You do too! ...........some time, when you pick up that (insert item here), be it a bushing, hex screw, hex key, bearing, spring, circlip, jewelers loupe, precision screwdriver, Torx bit, thrust washer, eyelet, chuck key, copper tube, socket, brass fitting, acorn nut, diode, e-clip, lathe bit, bit holder, drills, (enough Longboy)........You always clear the edge of the table you work at to "examine" the item either sitting on the stool hunched over or standing up.................where you develop an instant case of " Greasy fumble bobble-itis" and the part drops to the top of your toes and immediately jets 90 degrees straight forward under the table :redface2: .........I don't even have to go to Ace Hardware at the beginning of my build season anymore for a couple of weeks knowing that I just have to move the table out cuzz theres enough hardware under there to start a new project! Thm:
